New LS3060 some help needed
robburge@sky.com
Re: New LS3060 some help needed
Silly question perhaps - what is the top speed of my 3060? I've been using 200 but will it go faster?
Off the top of my head Rob I believe it's 500, (speed is usually MM's per second)
I don't think you will get much to work at that speed but I *believe* that's the max
Hi Just to let you know chris is importing a .75mm equiv of Rowmark and it works !!!!
At £7.00 per 4 x 2 its a 1/4 the price another worth knowing about also he has 1.5mm laminate at 15.00 ish.
Worth a try.
BOB
Worth a try.
BOB
robburge@sky.com
Thanks Bob
I actually got some from him when I picked my laser up. Its a little softer that Rowmark but it is possible to get quite nice details by doing a couple of light passes rather than in one go. I need to experiment a bit more but had quite a good result with two cuts at 75 power/ 35 speed
Rob
Rob
