Splines!
joem
Splines!
Post by joem »
I've scanned some handwriting in and converted it to vectors using autocad, I then splined (?) the resultant letters to make them all smooth. The problem is that when I import them into lasercut 5.3 (as a DXF), it imports both the spline and the original jerky line connected as one!
Is there any way to convert the splines into a series of polylines and arcs? Or maybe explode the lines in Lasercut so I can untangle them?
Thank you!
Using a Laserscript 3040
joem
Re: Splines!
Post by joem »
I've just figured out a very painstaking workaround.
Re: Splines!
I use modify, object, polyline, multiple, join (if required).
I also use a script called PLines diet to reduce some of the vertices - may not be the best/right way but it works for me ;-)
joem
Re: Splines!
Post by joem »
Cheers, I've just found the 'convert to polyline' option, I am now kicking myself :oops:
Re: Splines!
Hiya Joe,
When you save the file save it as "Autocad R10.dxf" ,
Release 10 doesn't support splines and will automatically convert them all to polylines :)
It will also ensure the splines are properly joined as they will convert as separate entities if not allowing you to rejoin them where required.
Users browsing this forum: No registered users and 25 guests
