laser cutting twice
woodturningbypaul
laser cutting twice
Post by woodturningbypaul »
Hi All
just noticed tonight the laser is cutting twice round each item, i have looked at the forum and it was surgested that it was the import, so i produced a square in lasercut 5.3 only which cut twice. Dont think i have changed anything. What would cause this.
thanks
Paul
Re: laser cutting twice
Daft question - on the panel on the laser - is Pieces set to 1?
Another thing I just thought of - last column on the cut/engrave speed/power settings there is 'Times' - any chance this has been set to 2?
woodturningbypaul
yep
never noticed that before
thanks
Paul
woodturningbypaul
sorry was replying to your question about the control panel
both the panel and the last column are both set to one
Paul
Can't think what else at the moment then. Will have a think ;)
If you draw a single line does it do that twice too?
woodturningbypaul
sorted !!
I have rechecked all the setting, the first piece I cut tonight I set the power and the speed and i guess tabbed onto the overlap which was set to 72, which i had not noticed. I reset that back to .1.
thanks for all your help dave much appreciated.
Paul
No worries - glad you sorted it ;)
