Hi All,
Not sure if this could be the answer, but it may be of use. If you press the return / enter button on the key pad to highlight the file and then press it again it opens the set datum window. If you press enter again it will set the datum to where ever the laser head is on the bed. It can be done quite easy by mistake! To turn it off press the return / enter button to highlight the file then press again, navigate to cancell logic org YES. That will turn off the set datum and return your machine to flying datum mode ( if immediate is ticked ) Hope this helps a little.
Cheers Simon
Unexpected behaviour
SimonMallas
Re: Unexpected behaviour
Hi try to check then uncheck the button before you download then download cfg - machine should BEEP.
previous files will keep their cfg settings so it may not be you if you re run old files...
