not cutting very deep
Kris and Dave
Re: not cutting very deep
Post by Kris and Dave »
Thanks for all the help guys. We are now up and running :D
Thanks to some support from a local engineer the following issues were identified:
  • The air compressor pipe was blocked
    The alignment was way out
    I didn't know how to focus it properly
    Everything was covered in soot from the series of small fires I'd caused by having a blocked air compressor pipe
The cut on HIPS isn't perfect and we may look at using a different material but playing with the speed and power settings we've got it pretty good now.
Off to play 8-)
HIPS is an aweful substrate to cut, the corners round and it gives off pretty nasty fumes :(
It doesn't *vaporise* in the true sense, it just melts and drips away :(
I discovered that one, shame, as it was ideal for thickness and colour.
