Power & Speed Settings for LS6840
tietheknot
Post by tietheknot »
Hello!
I'm a new owner of a 60w LS6840, i love the machine but i'm still struggling with power settings,
I'm used to a different type of laser and keep misguidedly trying to use the same power/speed combo!
Needless to say, i've made a few mistakes...
What i have noticed is sometimes my 3mm acrylic does not cut all the way through, slow speed and higher power,
Another problem i have encountered is the fact i am cutting wedding cards/stationary, my cards are pre cut at 300x150mm but when i put the template i've made in corel draw into laser cut, the size of the box when i press 'test' is completely different to what i've created, i'm having to increase the box size on screen to 320x160 to get it the same size as the material on the laser bed.
Do any of you fellow owners have any guides for this newbie?
Thank You in advance! :D
Re: Power & Speed Settings for LS6840
I cut my acrylic at 14mm/s @ 55% power on my 40W LS3020.
As for the sizing errors, I had these, and the consensus is to check all physical connections, check for backlash etc. I would cut a 50x50mm square / curcle in the laser software, to make sure that the sizes are what they should be.
Hiya,
What power settings are you using on 3mm acrylic TTK?
I've seen sizes out by a mill or so but 20mm and 10mm is a LOT to be out by,
test.zip
(7.91 KiB) Downloaded 462 times
download and cut the attached file and let us know what size it comes out.
tietheknot
Hello again,
The square cut out at 49x49 so i'm utterly confused why the card template is out by so much!?
I cut the 3mm acrylic on speed-8 power-50
I don't know if this is right?
The gentleman who came to install my laser was going on holiday and said he would email me a list of speed & power settings but I haven't received them yet, if any of you have them could you be so kind as to help a damsel in distress out!
I design everything in either illustrator on my mac and export to corel draw on my pc, or straight from corel draw to laser cut, I keep checking the size of the boxes i make to make sure they're the same measurements as what i need but like i say, i have to make them bigger to make them the right size when i press 'test'
Thanks again for the help :)
Ahh, makes sense, it's a legacy issue with corel draw and illustrator, neither are cad packages and their export format has some issues mostly with sizes.
The way Macs generate vectors and saves them is different to an x86 or x64 based system so they are not *really* cross platform compatible,for pictures or artwork it's fine but for cad work it can cause problems. I suspected it may well be something to do with that hence the test file (its a 50 x 50 polyline square).
I had a drawing arrive this morning done by a draughtsman friend of mine done with Corels X5 and when openned in autocad its sizes are all shot to hell.Most of it is due to underlaying functions of the different packages and the way they save and export files.Most of the extra stuff is carried over as a proxy item which is read by the laser *the best way it can* but very often not that accuratly.
For example Corels software will produce blocks, the downside is laser software can't read them and will often just try it's best but get it wrong.
If you are using different packages then I'd suggest the following?
1: Avoid using he Mac if possible,
2:Always save in AutoCAD 2000 format DXF
3:Where possible *save as * rather than *export*
4:If your using the laser for business purposes (where the cost can be offset) use an older version of AutoCAD, any version after 1999 is fine and will produce flawless files.Older versions can be purchased from ebay from 20 quid upwards.If you really don't want the cost of drawing software then use Draftsite from dassult systems, it's free and dies the best job of all the free cad packages.
Other than the odd mechanical issues the biggest problem I ever see with lasers is with imported drawings and the software used to produce them. For pictures (bmp etc) it really doesnt matter what you use but for vectors (cutting) a dedicated cad package is most certainly the way to go.
hope that helps
oops
speed wise 14 speed 75 power should fly through 3mm acrylic on that machine with ease.Even dropping down to 14 speed 65 power should work.It will go faster but reliable cut through can be a problem if the day gets hotter or humidity is up.
tietheknot
Ah that makes sense,
however, just to throw a curve ball -
i've just drawn a box in laser cut, 300x150 to cut a piece of paper,
the cut size that has come out is only 270x135,
I'm very confused as to whether i'm just doing something wrong, it worked perfectly the first few times i used the machine.
If you can figure this out i will be very grateful!
:D
Hiya,
Just before things changed did anything happen? machine get knocked? overheat? anything at all? pc connected to it crash?
The 6840 is usually very reliable for sizes and rarely does anything come loose. Try the test file again but cut say 5 of them and see if there is a difference, an unusual difference or variation usually suggests something is loose,the same amount of error every time usually suggests software problems (data file or driver corruption)
Also is the pc attached to the laser running much else such as games or applications?
tietheknot
Hey Spooky,
I'll cut the test files and see how we go, the computer has been a bit temperamental,
It has turned itself off once or twice and then come back to life!
Thanks for the software tip, i'm currently looking at auto cad :)
How would i know if the machine had overheated also?
Sorry for all the questions :)
forgot to mention, the pc i use doesn't run anything other than the laser stuff, i use my macbook for everything else!
Hiya TTK,
when you say "turned itself off" do you mean just gone ping and switched off or gone in to hibernation or blue screened? Also what operating system is it running?
Does the pc also have a normal printer attached / installed?
Overheating shows up as the machine moving round as normal but the beam itself turns off or starts to cut very thick lines....takes quite a while at lower power settings but is just something i want to rule out.
AutoCAD is great, it has a bit of a learning curve but many of the things that you will see when it's installed you will never use so don't be put off :) it's biggest downside is cost, the latest versions cost £thousands but to be honest the latest versions for laser use are masive overkill and a waste of money for what we do.Sadly I don't get the choice, I'm a commercial draughtsman so my clients expect the latest software to be used :(
Lets see how the 5 boxes turn out and that should get us a definitive answer, I'm still thinking about it being the drawings but want to rule out driver corruption (because of the lasercut file being the wrong size)
ask as many questions as you like :) that's why we are here :)
