i have managed to install newlydraw onto windows 7 (at least all seems to be working - have tried loading newlydraw on to xp mode of windows 7 but it isnt recognising the dongle for somereason?) i think all i'm missing is the usb drivers and it should work - but i cant remember where the usb drivers came from originally
any one any suggestions
drivers for 3060
Re: drivers for 3060
On my 3020 they were on the newlydraw software disc.
hi i found the drivers thanks - newlydraw seems to be working in windows 7 - but having a bit of an issue cutting - i can open the software jog the laser head around but when i press for it to cut i get link 5 error
Any suggestions
Thank you for your reply
Any suggestions
I could get ND to run on Win7 but not the laser drivers - if you find a way let me know
from memory the 3020 driver card isn't compatible with win7,
have since found it its a user specific thing the drivers must have installed under myuser name only - which is strange as newly draw works for all users.
the drivers installed fine????? - i have noticed an issue with 7 that if you install drivers following instructions it seems not to work - it tells you that it hasn't installed propperly - then gives you the option to install using recommended settings - hope that helps has helped for me in the past
That problem happened with all the graphtec drivers i installed.
Thanks for your replies and help
