This one is going to be ongoing but from initial experiments there are some huge gains to be had from running the correct temperatures of cooling water.
I spoke to an old friend @ M.I.T yesterday and he gave me quite a bit of info on the thermal effects of cooling NCh 10600 Nm laser generators, there is a magic number as such but until I can get to it reliably (read: at sensible cost I won't be able to post a curve showing cost / effect / efficiency.
Will be worth checking back as so far I'm getting a std 80watt CO2 tube to cut 3.2mm MDF at 65 power 35 speed.
More info as it becomes available.
Effects Of Cooling
Effects Of Cooling
Re: Effects Of Cooling
Very interested in reading your results on this one Dave.
Tweakie.
Tweakie.
I spoke to Chris earlier and there may well be a superchill in the pipeline,
I'm getting the kind of results I hadn't thought possible,all due to temperature control,tube life is another factor that will be affected
back in a bit
back in a bit
Sounds interesting - may save me dropping the ice pack in the water sh.... just remembered I've left it in there - she'll kill me if I forget it
