No, just regular stuff from the timber merchants.johnb80 wrote:Are you using laser mdf ? We've found a massive difference in specific laser materials compare to normal eg plywood, mdf etc.
To update, I'm getting good cuts across the whole sheet, except for the very top line? It's like the finish point is slightly higher than the start point, so it's moving upwards as well as horizontally on that line, resulting in a series of increasing height squares along the top row. Every other row is fine on the sheet.
Also, on some files I was getting random cuts all over, but when I've redrawn out the file, they're much better? Has anyone experienced problems with the software and possible corruption of the files?
