Wood Glue
Wood Glue
I picked up some of this stuff from Screwfix a couple of months ago, and gave it a go yesterday:
http://www.screwfix.com/p/no-nonsense-m ... 00ml/41795
Spray the activator on one part, then wait for it to dry. Use the included glue on the other part and press together. You will get no more than a second or so to position and it will stick! And honestly, it takes a lot to break them apart. A half of a 5p piece adhesion and I could not twist the 2 parts apart. I had to pry the 2 bits of ply apart to snap the glue. It left a couple of slivers of wood on one half, but came off mostly clean.
I recommend this! I have yet to try any other materials.
Mr Bea
Re: Wood Glue
Post by Mr Bea »
I agree with Philly Dee, used this stuff sometime ago and can't fault it for wood. I would be interested to hear the results for other materials though.
Colonel Blair
Not that technical I am afraid....
Re: Wood Glue
I was doing some test with plastic acrylic, smooth shiny, no keying!
The activator sprayed on the wood or the plastic works just as well as each other.
I glued plastic to wood, let it cure for a couple of hours. Clean removal was impossible. the plywood disintegrated and shards of the wood were left on the plastic.
Plastic to plastic, again, a good bond, the glue does melt the plastic, and then cures. I would use it for wood and plastic personally. Have not tried anything else yet, mainly as thats all I really have! Might try some aluminium.
Users browsing this forum: No registered users and 151 guests
