Card cutting
Card cutting
Do anyboy here cut card , i got a wedding coming up in the family and got to cut card / paper ect any info will be great thanks
Re: Card cutting
Hi ooper,
I sell cards through Etsy that are both engraved and cut. I just use Kraft card in A6.
I have a LS3040 with a 60 Watt Tube.
Settings I use are:
Engraving - 500% Speed, 20% Power
Cutting - 10% Speed, 15% Power.
Hope this helps!
Settings I use are:
Hope this helps!
Re: Card cutting
Thanks bud , could you tell me the settings you use for cutting 3 mm ply please
Re: Card cutting
Give Manila a try, Soft Card is a bit hit and miss when you Cut it and gives off a lot of Soot. Manila is a harder type of Finish and Cuts really well.
You'll get some good results using it.
Dynamode.
Dynamode.
Users browsing this forum: Google [Bot] and 4 guests
