Power setting issues on "Engrave"
ollyholford
Post by ollyholford »
Hello, I bought an LS3020 pro back in June and I'm having trouble altering the power setting when in engrave. The speed is set to 200 and the power 18. I want to change the power down but when I select the engrave mode, I change it to 15, press enter but the value still stays at 18 in the top right corner. Can anybody help? Also the software crashes a lot which is frustrating. It says not responding, and I have to force the program to shut and start again. Please help.
Re: Power setting issues on "Engrave"
What operating system are you using?
Is it Lasercut or Newlydraw software?
You need to press OK not Enter, enter applies to the cancel button :)
ollyholford
I'm on windows 7 pro and using the laser cut 5. 3. When I alter the power setting on cut mode it changes with enter. I'll try pressing ok and see what happens. Thanks for your help
ollyholford
Problem solved, on Engrave the value changes if you press OK, not enter, but on cut the value changes when you press enter. Thanks for your help :D
No problem :)
Users browsing this forum: No registered users and 24 guests
