Machine Will not move on X Or Y axis
Posted: Fri Jun 20, 2014 8:01 pm
by Shaker21
I just got back from HPC after having new bulb fitted 3040
Plugged it all back in and re loaded software and Laser firing on test laser I can also see the downloaded file on the machine but the heads on Y and X axis are not moving at all. nothing happens on test
If you press Run the clock times and it beeps for finish but no movement on the head
Help please if you can
Steve
Re: Machine Will not move on X Or Y axis
Posted: Sat Jun 21, 2014 8:03 am
by Shaker21
Anyone???
Posted: Sat Jun 21, 2014 8:07 am
by PhillyDee
What state is it? Does it move in manuAl mode?
Posted: Sat Jun 21, 2014 8:41 am
by Shaker21
No it will not move using up down arrows on the machine
You can move the head up and down and side to side with your hand
There are 2 black boxes inside with a Cat 5 sockets and a green and Red light on each unit. If I remember the green light used to be on. but no lights are on.
Posted: Sat Jun 21, 2014 8:43 am
by Shaker21
Are there any fuses anywhere that could have blown?
Posted: Sat Jun 21, 2014 8:53 am
Check the emergency stop button has not been pushed in - if it's not that call HPC.
Posted: Sat Jun 21, 2014 8:57 am
by Shaker21
Stop button OK
Yep another 11 hour drive by the look of it
Posted: Sat Jun 21, 2014 9:11 am
Yeah - sorry I re-read your message. It does sound like a loose/disconnected wire possibly bumped loose in the car. HPC may be able to take you through it over the phone?
Posted: Mon Jun 23, 2014 8:07 am
by Shaker21
Ive noticed that the 2 X Leadshine DM422 stepper motor drivers have a green and red light and am sure that the green light used to be on, but no lights are on both units. There is a cat 5/telephone socket on is it possible I need to download Software/Firmware or something?
