Hello, I stumbled across this forum and as I have a problem with my 6090 I wonder if anyone can help out?
When engraving I tend to get a double image everywhere except the outer edges of the engraving area. If I change it to engrave in one direction then it's fine, but things obviously take longer.
Any suggestions?
I look forward to hearing from you
Duncan
Hello from Duncan
Re: Hello from Duncan
sounds like scatter Dunc, check that the beam is exiting the center of the cone.
