Quick Tip / Fitting New Tubes - Aligning Mirrors
Posted: Wed Jun 09, 2010 5:35 pm
Just a quick tip, when your fitting a new tube or aligning mirror use a small square of acrylic to test fire the beam.
If you use paper or thin card the beam will burn through real quick and soot up your mirrors.
rgrds
Re: Fitting New Tubes - Aligning Mirrors
Posted: Mon Jun 14, 2010 9:10 am
by HPCLaser
Remember to "tape" this in place though (Health and safety)
Charlotte
Posted: Mon Jun 21, 2010 10:23 pm
by bob
Hi Spooky,
You can also turn the laser test power down in the keypad so its around 70% this makes it more accurate,
Also trying with clear acrylic works.
The last mirror is a pain as this is the one that can give double lines or angled cuts remember to adjust the opposite as it goes through the lens...
Re: Quick Tip / Fitting New Tubes - Aligning Mirrors
Posted: Sun Apr 17, 2011 9:56 am
by Bernie_of_CPE
Hi Guys,
Being a complete meddler by nature it occurred to me to substitute the units own laser for a visible one to perform the alignment work, it's safer and really should be a built in feature. Perhaps someone could suggest this as an improvement to the design to the Chinese manufacturers? It would be so much easier if adjustments can be made in a "live" situation where the effect of the adjustment can be seen as you do it.
So far I have bought a cheap laser tape measure from B&Q (the UK version of Home Depot), the laser unit is small and removable and I am sure could be mounted in the output path to show beam redirection along the mirror route. A small laser etched target made to mount on the last mirror block is all that will be needed. Once set up I am sure this would make aligning mirrors a cinch.
Alternately by removing the bed and mounting the visible laser into the output nozzle sending the visible beam laser the wrong way through the output nozzle and back to the tube could be a better option. This could certainly be done in my 6090 Pro. I will give this more thought and mock something up. I just think that using a lower powered laser with a constant beam to test alignment would make this job so much easier.
I'll let you know how my tests progress.
Bernie
Posted: Sun Apr 17, 2011 10:10 am
I was thinking the same Bernie - I had a laser sight from an old saw but it produces a line rather than a spot but the unit itself is small enough to rig something up!
Be interested how you get on!
Posted: Sun Apr 17, 2011 11:46 am
by PhillyDee
I do something similar with telescopes. Its alled collimation, and they use off the shelf laser pointers. You could use a Green laser pointer, as the beam is visible in the dark.
Posted: Sun Apr 17, 2011 5:28 pm
or look at the CO2 beam via a digital camera
they pick up radiation in that spectrum
Posted: Sun Apr 17, 2011 5:51 pm
Maplins sell
these. Could be useful
Thinking about it how would you get the two laser beams parallel?. I was thinking you could find the laser cutter beam using the acrylic on the first mirror method but then if you point the diode beam at the same spot it would have to come from the same co-ordinates.
If you cut a plate with a cone to center on the end of the tube that the diode was then attached to - would that work? Does the beam always come from the exact centre of the tube? Interesting
Posted: Tue Feb 21, 2012 7:13 am
by SimonMallas
Hi Dave,
Working backwards from the nozzle Would be so complicated, as the laser tube can be in any position. Alot of other machines have got this feature, its a bit like the auto focus, your never quite 100%, so end up manually checking it!! and really alignment isn't really hard or time consuming to do, as long as you stick to the rules.
Cheers Simon
