Newbie with a 3020
Posted: Thu Mar 10, 2011 4:35 am
Hi guys, I'm Leon, based up in Middlesbrough.
I'm hoping that my newbie questions don't sound too daft! I purchase the 3020 last November, to cut squares/rectangles out of 2mm MDF, from 15x15mm upto 80x80mm. It took a while for me to get to grips with the machine, but once I was up and running, everything was great. However, 5 months down the line, I'm getting some little niggly problems which I'm hoping someone can help me with?
Speed/Power
I originally set the machine to Sp 20 / Pow 20 as Chris recommended, and this worked great. An A4 sheet of MDF took around 4 minutes to get through, clean cuts, no bother. Gradually the cuts stopped going all the way through, so I increased the power and slowed the speed. I'm currently cutting at Sp 8 / Pow 45%, which has put an A4 sheet up to 9 minutes. Does this sound right? Does the machine/laser take a bit of time to bed-in and this is the kind of speed I should be expecting?
Cutting Accuracy
When I first started, every cut was perfect, the squares all matched, and I didn't have to check them much at all. I'm now getting odd sized ones though, with upto 2mm difference between them? The template I'm using hasn't changed, but on a full grid of 40x40mm squares, some are 40x38, 40x39, etc. I have a lot of different templates set up for different size squares, and the same thing happens on all of them. Strangely, the vertical cuts are fine, it's the horizontals which are either too high or too low. Any idea what's causing this?
Cuts
Really an extension of the above, a lot of the cuts aren't vertical (90 degrees to the cutting bed), some are probably around 30 degrees off vertical?
Flame
From day one, there's been a flame while I'm cutting. It doesn't seem to do any real damage, but it's blackened the cable ties around the laser head, and when I've tried doing circular cuts, I get very worried that the flame is going to damage something. Should I be worrying about this? And is there anything I can do to reduce the flame?
Cleaning
I've always tried to clean regularly. The machine has only been used for 5 hours per week since I got it, probably even less. I bought some alcohol and cotton swabs, and I've been cleaning the end of the laser tube, the 3 mirrors, and the cone where the laser comes out. It's only really the cone which shows any dirt on the swab, but, will dirt build up inside the cone, and should I be taking it apart to clean inside? I've washed the honeycomb a couple of times as well, but that's about it. I've not cleaned the running tracks or anything like that.
Apologies again if the any of the above is something obvious. Before buying the machine, I'd never even seen one before, so it's been a steep learning curve. I've been reading the other threads, and there's some good info I've picked up, but nothing quite explains the problems I seem to be having. I've gone from getting a full perfect sheet of squares in 4 minutes, to getting 60-70% worth of squares in 9 minutes. Any help would be really appreciated.
Cheers!
Speed/Power
Cutting Accuracy
Cuts
Flame
Cleaning
Cheers!
