Hi, I have a 3060, my problem is raising and lowering the bed. I thought when you pressed Z if would start to lower and then after a couple of seconds it would start to go quicker. However after a couple of seconds mine just stopps and then I have to take my finger of the button and start again. to move an inch either way takes about 10 - 15 minutes. Is this correct?
Many thanks for any help.
bed raise/lower
Re: bed raise/lower
Yep that is the same on mine - if you press datum it will re-set back to the top on it's own.
The speed is slow though - should be quicker than that - make sure the belt isn't slipping.
Re: bed raise/lower
I have the 3060 and the Z speed is pretty quick by comparison - press Z then use up and down arrows to adjust the bed, using your little measuring thingy on the laser to get the correct depth, or defocus of you wish, and then press Z again to confirm and you're done. Mine moves instantly when pressing arrow buttons, and an inch shouldn't take 10minutes, more like a few seconds. Check you don't have anything under the tray, or blocking it somewhere.
