Hi all and thanks for having me.
I have just recently taken delivery of an 80w HPC 6090 and am struggling to cut 3mm MDF without smoke contamination on the top surface of the sheets. I use a BOFA AD Oracle for extraction.
I also have a smaller 40w RDL 4040 and cut 3mm MDF with no issues.
On the HPC I have so far tried higher power and speed, lower power with higher speed and lower speed. I have also put on a larger air pump than the one supplied (still a pump not a compressor). I have this problem just when cutting, engraving is not causing any issues so far.
The issue seems to be the distance between the nozzle cone and material is quite a lot larger on the HPC than it is on the RDL and the "exit hole" from the cone again is larger on the HPC than the RDL therefore the air assist is not as concentrated at the point of cutting.
So my question is should I invest in a compressor, and if so would I then need to fit the ultimate air assist set up; Or is there anything such as a nozzle extension available.
Newbie from Blackburn
Re: Newbie from Blackburn
Hi - Welcome,
Have a word with HPC they may have a longer nozzle that will fit - the newer 3060's are certainly longer.
Cheers Dave
I will have a word with them.
Andy F
Andy F
No problems,
I have spoken to Chris at HPC and there are UK H&S considerations regarding the method of controlling the air assist so on that basis we recommend not fitting and device that is controlled via the laser or laser software.
Thanks again Dave
I will try and find a suitable alternative nozzle perhaps longer with smaller diameter exit hole, hopefully this will help concentrate the air at the melt point.
Andy F
Andy F
