One compressor, two lasers?
cd1986
Post by cd1986 »
Is anyone using one air compressor for more than one laser cutter? (specifically, one 22l Titan silent compressor with two LS6840’s?)
Re: One compressor, two lasers?
I did for a while on my two 3060's - apart from having to kick in more often it worked ok.
cd1986
Post by cd1986 »
Great. Did you just use a y splitter somewhere in the line and get another regulator for the second machine?
No - regulator then y splitter then one of these for each machine
Remember though I am using it as an open system so turn of the flow from the compressor valve.
I do drain the compressors when I remember but not had an issue with condensation reaching the work.
UPDATE
I have spoken to Chris at HPC and there are UK H&S considerations regarding the method of controlling the air assist so on that basis we recommend not fitting any device that is controlled via the laser or laser software.
