Upgrade of Compressor
Posted: Mon Jan 25, 2021 1:16 pm
I have seen in some posts within the forum that upgrading the air assist compressor helps cutting etc. The Titan 21l appears to be the most recommended replacement and is quite reasonable cost wise. My question is what about the pipe from the compressor to the port at the back of the laser (3060 pro)? Can it be left as it is or should it be increased in size, if so to what ID/OD? Could silicone tube be used rather than nylon, only because it is far more flexible? Lastly if the pipe from the compressor to the laser is increased what about the internal pipe, should this also be increased? Again if so to what size, though assume this would invalidate any warranty, but could do it after that has expired.
Thanks in advance
Mark
Thanks in advance
Mark
