LSC3020 Tube failing?
Posted: Sun Nov 20, 2016 11:19 pm
by dreamcatcher
Please can anyone advise? We've had our 3020 since February and are starting to get the hang of it at last. :)
Recently though the engraving especially on wood does not seems as good as previously. It is a bit fainter and not as deep. I've tried making the scan gap smaller and it's a bit better but still not quite like it was. The acrylic engraving is ok though. Could it be a sign that the tube is starting to fail? I don't know what to look for as a sign that we may need a new tube. Does the quality of engraving and cutting deteriorate or does it just pack up altogether?
If we need a new tube where can we get one from please. I don't think HPC deliver and we are a very long way from Halifax. Would a 40W chinese laser tube from Ebay fit do you think?
Thank you very much for any ideas.
Re: LSC3020 Tube failing?
Posted: Mon Nov 21, 2016 7:56 am
I would be surprised, have you cleaned all the optics including the one in the end of the tube (be very careful cleaning this as if you scratch it there is no way to replace) ?
A tube does degrade a bit after a while but then stabilizes for most of it's life and then starts to degrade quite quick. You will notice the need for more power on all materials, cutting and engraving.
Ply can change from sheet to sheet - could it be a different batch that is causing the issue? Does it cut using the same power as before>
Posted: Mon Nov 21, 2016 3:36 pm
by dreamcatcher
Thanks very much for your help. I'm using 4 mm Oak veneer. You could well be right about the wood as it doesn't look as good as my last batch. The optics have all been cleaned but will check them again.
It's quite a relief that we may be ok with the tube for a bit longer. :D
Thanks again
Posted: Mon Nov 21, 2016 5:08 pm
No problems - Oak can be difficult ;)
