No power to psu .
exengrav
No power to psu .
Post by exengrav »
Trying to help my previous employer today, before they have to take it further and spend money they haven't got. The laser stopped firing mid cut. I tried bypassing the door and flow switch to eliminate them, still no laser firing. There are no leds lit up on the power supply when the machine is switched on, presumably indicating that there is no power to the psu ? Does anybody know if this is internally fused ?
Re: No power to psu .
Post by Lightnin »
which machine is it ?
Presume the RCD has not tripped? Tried pressing the red stop button and resetting?
exengrav
Post by exengrav »
Machine is a 6840, no the rcd hasn't tripped.
Post by Lightnin »
I guess you checked all connections are secure and tight ?
just ruling out anything that isn't money costing !
in a commercial set up, you are limited on what you can check, unless you are qualified !
exengrav
Post by exengrav »
Correct myself - power to PSU, because an led is lit, but no power to the tube . All connections are tight. Everything else happens - laser head moves and thinks that it is cutting, just no laser beam.
