NIce find - thanks! If that could be bolted onto my workbench, I probably wouldn't need to make a table!PhillyDee wrote:http://www.diytools.co.uk/diy/Main/sp-5 ... sander.asp
Plenty of others around for drum sanding. Axminster power tools have similar things.
And as for making the table, you could always use a laser cutter to make the table . . . .
I've got an early Flying-V out of the bin (it was really badly cut on the BuildBrighton laser cutter and after two passes still had to be snapped out of the acrylic sheet) and taped it together. I think four sheets should give a nice thickness (and weight) to the body.
So if I can sand/polish the edges, I think it'd look ok.
There's a very noticeable kerf of the edges of these pieces - my guess is that the cutter at BuildBrighton needs setting up properly, mirrors aligned and all that (I don't really know much about laser cutting, but have heard all this mentioned on other posts on the forum!). It would probably take a lot of polishing to get them all smooth and inline. Would sanding first, then polishing, ruin the finish on the edges of the acrylic? (when I get my own laser cutter I'm hoping the kerf won't be quite as bad as this, but it may still be visible).
Total thickness = 12mm. Slot for the neck is 6mm deep, so I can use 6mm mdf/ply/wood and then the fingerboard (which is really a PCB with a vinyl sticker over it) goes on top, standing proud of the body where it meets at the neck joint - just like a real guitar!
