When you have aligned the number of machines Chris has I guess it becomes 2nd nature
Using two LS3060's and an ex 3020 user Please note I am not employed by HPC, any advice or recomendations I give are based on my own experience and are not necessarily the same as HPC's. First point of contact on any hardware issues should be with HPC
I've never been able to figure in my head what difference the tube level makes ?
it could be off by 45 deg and you'd still be able to get a dead strait level beam from mirror X to mirror Y
which is what really matters
EDIT .. as long as you can hit mirror 1 dead center
I may be wrong but it could be to do with the profile of the beam - keeping it level gives a better spot profile.
If the tube is too low but is level you need to lower the 1st mirror or raise the tube - tilting it may work but there may be a small loss in power.
