Just bought off ebay a used 6090 which needs a full overhaul which hopefully we can do.
A couple of early questions - what is the fuse size in the rear fuse holder please and is it possible to get a demo copy of Lasercut 5.3 without having to buy the dongle just so we can make sure that everything works
Hi from a 6090 used user
Re: Hi from a 6090 used user
Hi - I can't help with first question, drop HPC an email
There used to be a demo version on Letros website but it would not let you test the machine. You may also need the cfg settings and the drivers to use the machine.
You can test to see if the laser fires from the control panel if it does you can then see if there are any files left in memory, failing that have a word with HPC and see if they can email a simple file that you can load onto the machine via the usb memory stick port.
