Hello
New to this and the laser machining.
Great bit of kit just a quick question ours has a black temp sensor out the back where do I place this sensor do I just hang it so senses room temp or does it go in the water to get water temperature when machine operating.
Sorry didn’t see this in instructions
Temp sensor LS3040
Re: Temp sensor LS3040
That's new! I should imagine the water as that is more important - anything over around 21 degrees and there is a chance the tube will overheat.
I keep mine at 13 degrees which seems to work well.
Thanks for reply much appreciated
Users browsing this forum: Ahrefs [Bot] and 2 guests
