Adobe Illustrator to Lasercut 5.3
Ryanjmurphy
Post by Ryanjmurphy »
Evening All,
Just purchased a LS3060. I'm very new to laser cutters.
I am familiar with photoshop and Adobe Illustrator, however I am REALLY struggling to get anything to import properly in to Lasercut 5.3.
I have Corel Draw also. Can anyone help me out, what software should I be using and what export settings?
I am trying to use the test cut pattern on this website, but it will not import correctly from any of the programs:
https://www.thingiverse.com/thing:2243854
Thanks in advanced.
Ryan
Re: Adobe Illustrator to Lasercut 5.3
You need to export/save as DXF and then import that into Lasercut.
You can interface CorelDraw but I don't use it so not sure how or what formats I'm afraid.
Ryanjmurphy
Daven wrote: ↑Wed Jan 09, 2019 8:59 am You need to export/save as DXF and then import that into Lasercut.
Thanks Dave. I think it may be the file that I'm trying to convert.
What is the recommended editing software to use other than AI and Corel?
For DXF cad files I use BricsCad but there are some free programs available like DoubleCad or DesignSpark Mechanical. I used to use AutoCad but the cost is greater than the need ;)
PS the template file is a bit over the top to start of with to be honest - it has a mixture of engraving and cutting with different setting which all need to be on different layers. Start of with something simple - if just cutting I use that same Idea of the squares and circles each set on different layer with incremental speeds (3mm ply set at say 65% power and speed starting at 18mm's, next set 20mm/s and so on).
Ryanjmurphy
Daven wrote: ↑Wed Jan 09, 2019 10:15 am PS the template file is a bit over the top to start of with to be honest - it has a mixture of engraving and cutting with different setting which all need to be on different layers. Start of with something simple - if just cutting I use that same Idea of the squares and circles each set on different layer with incremental speeds (3mm ply set at say 65% power and speed starting at 18mm's, next set 20mm/s and so on).
Thanks Dave. I'll give it a go!
Rog
Post by Rog »
Another decent free CAD program is Draftsight.
My wife also uses inkscape (also free) which is more of a design suite (like illustrator).
If you use draftsight, just make sure you close the drawing when wanting to import to lasercut or else it won't open.
tilltots
Post by tilltots »
We do this and find it easiest to open the .ai file in Inkscape, ungroup all of the items and ensure all objects are converted to paths then save a copy as a .dxf. Inkscape cannot export to a .dxf on a mac correctly though. I find Inkscape easier to use than a CAD program as it mimics a lot of the functions in Illustrator.
LS3060 with a 60W upgrade
