hi all,
just wondering if someone can either help me or put me out my misery
i have a 6840 and it recently had a new tube fitted, cut perfect.... before the tube was fitted i had a problem where it would cut very well on the right hand side of the bed but on the left it struggled to maintain the same quality, as in it wouldn't cut through, i knew the bed was level as the two red dot diodes formed one singular dot and the engineer that came to fit the tube noted that it must of been alignment of the mirrors....
so my problem that was then as now come back with a vengeance!!! now surely if i was to suffer loss of power it would be further away from the left hand side, but not my problem
i have tried to align the mirrors myself and i have come to the conclusion that i am ridiculously poor at completing said task, has anyone else experienced this problem if so please help.
cheers,
Sean
mirror alignment help!
Re: mirror alignment help!
I would check how well centred the beam is hitting the entry hole in the head in each corner of the table and adjust as necessary then check the beam is exiting the nozzle in the centre and adjust.
It can be tricky to get just right but you can do it
