Help
Help
Help!! Received laser yesterday and since training not been able to do any cutting or engraving what have I done ! Did a step by step and all is good laser just isn't firing up !!!
Re: Help
Re-set the red emergency knob just in case it has been pressed.
What happens when you turn it on and does the head move as if it is cutting?
Re: Help
Yes head was working for full project . I ended up calling for help and Johnathan at hpc lasers ran over a few check points and it was a air bubble which we had an issue with at install ! Got it cleared cut one shape thank goodness I'd thought I'd broke it
Need to check it tomorrow again . Thanks for getting back to me Dave
T
T
Re: Help
Bubbles are a pain, if they are too large they will slow the flow down. I have found that keeping the tank and pump on a level with the tube helps also keeping the pump running 24/7
Re: Help
Only me again.
Im having an issue now not engraving well it starts to engrave a few lines then continues to the cut !?? As any advice would be great need to go play tx
