Hi all
I have a 2008 6040 and noticed some banding on an engraving and then the PSU started cicking when i ramped up the power, i have since noticed some arcing inside the unit near the negative wire and turned it off straight away.
I have had banding issues before but HPC changed the tube and seemed to go away, does anyone know if a faulty PSU could be cooking my tubes too???
Thanks in advance
Nigel (why do these things always seem to happen when you have loads on?)
psu clicking
ncamacho2000
Re: psu clicking
1st of all, check all the wire connections are good and tight - if you are comfortable doing that ?
If not, get someone else to have a look.
The transformer output can remain charged for quite a wile after it is switched off
