Yup, looked into a flame seeker type setup ran from an Arduino, but it would be no good.Spooky wrote:The problem with fire sensors is the way they work, they either sense IR from the flame source or heat, both of which happen in a laser machine anyways
Best way to avoid fires? watch the machine..hence the big warning stickers on them
As for the extraction, mine is excellent, a 420m3/hr vent on a 6" direct hole. It was so good, that despite the fact that I burned through half a 600x600mm sheet, and it turned the entire inside of the machine black with soot, I never so much as got a whiff of anything at all. And this was with about 20psi of air assist on a blade table with what, 12-14" gap underneath?
