3060 vs. 3050 vs. ...
JamesW
Re: 3060 vs. 3050 vs. ...
Post by JamesW »
Hi DaveN,
Worthwhile knowing - I was presuming that I wouldn't need a chiller until Spring - but I'll be ready to grab one if the water exceeds 25C. What chillers do you recommend? The ones supplied by HPC, or any? Is their listed 2361 BTU/hr good for more than one laser (with shared reservoirs) or do you need one per laser every time?
Thanks,
James
Hi James,
The HPC one should be fine - I don't have the same one as I had to buy locally to finish a rush job on a rather exceptional hot day. I use one reservoir for both machines but I would check with HPC ;)
