I have a sample i need to produce for a client which has to be accurate as it is for scale modelling.
I will produce the cut file using auto cad and then import the dxf file into the laser cutting software to cut the item.
The item is small around 20mm x 15mm and needs to come out that size, i am interested in the cut out piece,
does anyone know what offset i.e. the width of the laser cut that i will need to apply to my drawing file so that it comes out the correct size.
Gary
Laser cut design offset width
If it was that easy everyone would be doing it
Re: Laser cut design offset width
Hi Gary,
Depends on the tube I guess but I normally offset at .25 - say if the kerf is .5 of a mm this would be half. Think spooky put a post up about this a while ago, will see if I can find it
thanks Dave, this forum is great and fast.
