Laser keeps printing same old file
oyoung
Post by oyoung » Thu Oct 22, 2020 5:53 pm
Hi - I downloaded a file to the laser from LaserCut 5.2, and the filename has changed on the little screen on the HPC Laser 6540.
However, it is still cutting the last file! How can I remove the last file from the memory, and cut the new one?
Thanks.
Re: Laser keeps printing same old file
Post by Daven » Thu Oct 22, 2020 6:44 pm
You can delete a file from the panel on the machine using the arrow keys or from LaserCut by selecting delete all files before download.
oyoung
Post by oyoung » Thu Oct 22, 2020 6:59 pm
Yes, I did that. I have used this machine for 10 years - this is a new problem, out of nowhere.
Any more ideas gratefully received...
Post by Daven » Thu Oct 22, 2020 7:02 pm
So sounds like a card issue - if you can't delete it by selecting it from the control panel or the software it may be an issue with the motherboard. You could try loading a file using a USB stick and see what happens...
oyoung
Post by oyoung » Thu Oct 22, 2020 7:53 pm
TBF the files I have been cutting are edited copies of each other. It was fine for the first few, but one started sticking...
I'll try a different file tomorrow. Thanks.
Post by Daven » Thu Oct 22, 2020 7:59 pm
If it is the same file name that does happen- swap a layer colour or rename. You should still be able to delete the file to there are none left in the memory though!
oyoung
Post by oyoung » Thu Oct 22, 2020 8:46 pm
I'll try a different layer colour, but they are saved as different names...
