One compressor, two lasers?
Is anyone using one air compressor for more than one laser cutter? (specifically, one 22l Titan silent compressor with two LS6840’s?)
Re: One compressor, two lasers?
I did for a while on my two 3060's - apart from having to kick in more often it worked ok.
Great. Did you just use a y splitter somewhere in the line and get another regulator for the second machine?
No - regulator then y splitter then one of these for each machine
Remember though I am using it as an open system so turn of the flow from the compressor valve.
I do drain the compressors when I remember but not had an issue with condensation reaching the work.
UPDATE
I have spoken to Chris at HPC and there are UK H&S considerations regarding the method of controlling the air assist so on that basis we recommend not fitting any device that is controlled via the laser or laser software.
Users browsing this forum: Ahrefs [Bot] and 3 guests
